Hi Tom!
First I want to Thank You for your support in helping to solve this.
I got my spindle under control with following:
//Plugin Notifications and defines..
enum { EX_DDA , EX_VMS, EX_COMMAND, EX_SPINON, EX_SPINOFF, EX_SPINSPEED, EX_MOTORTUNED
, EX_SETUP, EX_FEEDHOLD, EX_RUN, EX_ESTOP , EX_CONFIG };
#define SPINDLE_AXIS 3 // axis set up as Spindle, possibly Step/Dir or Servo
#define FACTOR 226000.0 // Converts fractional pulley speed to counts/sec (may be negative)
int message = persist.UserData[0]; // Mach3 message ID
int Direction = persist.UserData[1]; // Mach3 Spindle Direction
float speed; //= *(float *)&persist.UserData[2]; // value stored is actually a float
int DirFactor = 0;
//if (Direction==0) DirFactor=-1; // change Direcion 0 or 1 to DirFactor -1 or +1
if (Direction==0)
DirFactor=-1;
printf("Spindle CW ON\n");
else if (Direction==1)
DirFactor=1;
printf("Spindle CCW ON\n");
printf("Mach3 Notify Message=%d, Direction=%2d, Spindle Set to %f\n",message,Direction,speed);
switch (message)
case EX_SPINSPEED:
DefineCoordSystem6(0,1,2,-1,-1,-1);
speed = *(float *)&persist.UserData[2]; // value stored is actually a float
printf("Spindle Speed Set to %f\n",speed);
Jog(SPINDLE_AXIS,speed*FACTOR*DirFactor);
while (!CheckDone(SPINDLE_AXIS));
break;
case EX_SPINON:
if (Direction==0)
DirFactor=-1;
DirFactor=1;
//Jog(SPINDLE_AXIS,speed*FACTOR*DirFactor);
break;
case EX_SPINOFF:
printf("Spindle Stop\n");
DirFactor=0;
Jog(SPINDLE_AXIS,0.0);
while(!CheckDone(SPINDLE_AXIS));
DefineCoordSystem6(0,1,2,3,-1,-1);
break;
It may well be that this is not the most elegant solution but it works:
-Spindle speed and speed changes on the fly OK
-Both M3/CW and M4/CCW OK
-Manual Jogging OK
-controlled motion (G0 A90 etc.) OK
Only small beauty flaw is that if I enter spindle speed manually after Mach startup the spindle will start without activating the EX_SPINON. I need to set the rpm to 0 to stop the spindle and click spindle start twice. After that it works.
I see Steve is also struggling with the mach spindle. I don't know if this helps, but it's one possible solution.
Rgds,
Tapio
--- In DynoMotion@yahoogroups.com, "tapiolarikka" <tapio.larikka@...> wrote:
> Hi Tom!
> So this means then that for some reason the Jog(SPINDLE_AXIS,speed*FACTOR*DirFactor);
> in my code below does not get properly updated.
> I'll have to try to rearrange the code.
> Then this also means there should be no problems with lathe constant speed once I got this working.
> Rgds,
> Tapio
> > Hi Tapio,
> > No. Every time the GCode changes the speed Mach3 will send a message to the Plugin to re-launch the Spindle Program with the new settings. You should be able to change the Spindle Speed whenever you want from GCode.
> > ________________________________
> > From: tapiolarikka <tapio.larikka@>
> > To: DynoMotion@yahoogroups.com
> > Sent: Monday, April 29, 2013 12:10 PM
> > Subject: [DynoMotion] Re: SpindleMach3Jog
> > Â
> > Hi Tom!
> > I'll try that tomorrow to find out if it helps to changing spindle speed. That will make me lose the spindle as A-axis so it is not a final solution.
> > I just read your answer to Steve regarding mach spindle&messages a few posts back. You wrote that activation, direction and speed is written to Kflop before C program is launched.
> > Does this mean speed is written only once and therefore not updated if there is change in G-code?
> > Is there a way that I could add the spindle routine to he WatchEnable loop at the end of init?
> > Rgds,
> > Tapio
> > > Hi Tapio,
> > > I think the problem has to do with you defining the Spindle to operate like an A axis and to be part of the Coordinated Motion System, and then commanding it to Jog like a normal Spindle.
> > > Try removing the function calls:
> > > and only add
> > > to your initialization program to keep the Spindle always out of the Coordinated Motion System.
> > > HTH
> > > Regards
> > > Sent: Monday, April 29, 2013 7:29 AM
> > > ÃÂ
> > > Hi Tom!
> > > I'm almost done with my spindle setup.
> > > I rewrote the SpindleMach3Jog to:
> > > main()
> > > int DirFactor = 0;
> > > switch (message)
> > > case EX_SPINSPEED:
> > > break;
> > > case EX_SPINON:
> > > if (Direction==0)
> > > DirFactor=-1;
> > > DirFactor=1;
> > > break;
> > > case EX_SPINOFF:
> > > DirFactor=0;
> > > while(!CheckDone(3));
> > > break;
> > > and now start/stop works like it should.
> > > Last problem to solve with spindle is speed change:
> > > G95
> > > S200 f0.06
> > > M3
> > > g1 x10
> > > g1 x0
> > > M5
> > > M30
> > > works fine, but
> > > G95
> > > S200 f0.06
> > > M3
> > > g1 x10
> > > S400
> > > g1 x0
> > > M5
> > > M30
> > > Runs fine until x10, then spindle stops, program execution continues until x0 and at x0 mach resets and indicates "a-axis disabled"
> > > Is there something missing from my SpindleMach3Jog.c that causes this?
> > > in other words How do I change Spindle speed on-the-fly?
> > > Rgds,
> > > Tapio
> > > > Hi Tapio,
> > > > The Plugin needs the quadrature counts/rev (4 x the cycles/rev) set correctly to have Mach3 report the speed correctly.
> > > > Get that to work first.ÃâàIf one obvious thing is not working it just adds confusion to go on to the next thing.
> > > > Do simple tests to check your resolution. Rotate the Spindle 1 rev and check how much the Axis Screen shows that the counts changed.
> > > > Enter that value into the Mach3 Plugin for the encoder.ÃâàThe displayed speed should then report correctly the true speed.
> > > > Regards
> > > > TK
> > > > Sent: Sunday, April 28, 2013 11:01 AM
> > > > Subject: [DynoMotion] SpindleMach3Jog
> > > > ÃâÃÂ
> > > > Hi Tom!
> > > > I broke the questions in my previous post under separate topics, so here is the second question.
> > > > I'd be interested to hear from people using SpindleMach3Jog if you had similar issues and how you solved them?
> > > > What should be entered in the plugin config for encoder counts? Encoder ppr or ppr*4?
> > > > With 2560 counts/rev and following code:
> > > > #include "KMotionDef.h"
> > > > #define FACTOR 10240.0 // Converts fractional pulley speed to counts/sec (may be negative)
> > > > main()
> > > > float speed = *(float *)&persist.UserData[2]; // value stored is actually a float
> > > > int DirFactor = 1;
> > > > switch (message)
> > > > case EX_SPINSPEED:
> > > > break;
> > > > I get movement that starts as soon as enter the rpm and press enter and continues until rpm is set to 0.
> > > > With requested 200rpm the true output is 100 rpm, but mach reports something around 1500 (can't remember exactly).
> > > > If I start the movement from G-Code/M3 the G-code execution hangs.
> > > > Start/accel and stop/decel of movement are nice, as they should.
> > > > I changed the above to:
> > > > case EX_SPINSPEED:
> > > > break;
> > > > case EX_SPINON:
> > > > break;
> > > > with this I get
> > > > movement that starts when I press spindle start.
> > > > With requested 200rpm the true output is 100 rpm, but mach report something around 1500 (can't remember exactly).
> > > > Start/accel and stop/decel of movement are very rough, with short delay and vibration/jerk like the servo is about to brake into oscillation.
> > > > How could I get around this?
> > > > Rgds,
> > > > Tapio
